Some features only available with SCS-Standard and/or higher license levels.
For an SFR cue or sub-cue, the lower panel to the right of the cue list tree will contain properties specifically for stop / fade-out / loop release sub-cues. For example:
Sub-Cue Relative Start Time: This field is available for every type of sub-cue. Click here to see the description of this field under Audio File Cues. Then click the Back button in the Help Viewer to return to this page.
Description: Enter a description for this sub-cue. You can leave this field blank and let SCS create a default Description for you from the first line under Cue to be Actioned and Action Required.
Cue to be Actioned: The drop-down list here will display a list of all Audio File, Playlist, Video/Image and Control Send cues. Additionally, the first three lines of this list contain the entries All earlier cues, All playing cues and Previous cue .
·         All earlier cues - This option will cause the SFR cue to act on all cues earlier in the cue list than the SFR cue itself. If you select a Fade Out or Stop action for this SFR cue, then all earlier cues will be marked as completed (after they have been faded out if required, and stopped). So even if an earlier cue has not yet been started it will still be 'completed'.
·         All playing cues - This option will cause the SFR cue to act on all playing cues only, regardless of whether they are earlier or later in the cue list. This option is particularly useful if you want to set up the SFR cue as a hot key cue (although see <Cues...> below). Only playing cues are affected, so cues not yet started will remain 'Ready' (or 'Not Loaded', etc). For a Fade Out or Stop action, playing cues will be marked as completed (after they have been faded out if required, and stopped).
·         Previous cue - This option will cause the SFR cue to act on the previous cue enabled that contains an Audio file, Video/Image file, or a Playlist. This is useful for providing an SFR cue that fades or stops the previous cue where the actual previous cue may vary, such as due to a cue being disabled or because you are importing the SFR cue from another cue file. Note that this option acts on the previous cue in the displayed cue list, which may not be the same as the most recently started cue.
·         <Cues...> - The remainder of the list will show all cues. Selecting a cue or sub-cue will cause the SFR cue to operate on that cue only. You would normally select a cue that's earlier in the cue list than this SFR cue, but there are some occasions when you would want the SFR cue to affect a later cue which is why the full cue list is included in the drop-down list. An example of using an SFR cue on a later cue is if the later cue is a hot key cue, or if you have set the 'Run Mode' Production Property to non-linear.
·         All earlier cues EXCEPT cues listed above - This option acts on all earlier cues except any cues listed earlier in this same SFR cue. This is particularly useful if you have several cues playing including a playlist and you want to hibernate and fadeout the playlist but fadeout and stop the other cues. To do this, include a 'fade out and hibernate' for your playlist as the first entry in the SFR cue, and a 'fade out and stop' for 'all earlier cues EXCEPT cues listed above' as the second entry in the SFR cue. Note that both of these entries must be in the same SFR cue.
·         All playing cues EXCEPT cues listed above - This is similar to 'all earlier cues except cues listed above' except that it acts on playing cues only.
Action Required: The following actions are available:
STOP Immediately - do not fade out
Causes the selected cues to be stopped, closed and marked as 'completed'.
FADE OUT and then STOP
Causes the selected cues to be faded-out provided those cues have a fade-out time specified, or a Time Override for Fades has been entered. At the end of the fade-out, the cue will will be stopped, closed and marked as 'completed'.
RELEASE from Loop and then play until end point
This applies to cues that contain loop points ('loop start' and 'loop end'). The Loop Release will cause the selected cues to have their current loop released, ie when the cue next reaches the 'loop end' point the cue will keep playing up to the 'end at' point, or until the end of the file if no 'end at' point has been specified.
STOP Playlist at end of current track
For playlist cues only, this will stop the cue when the currrent track ends.
The following 'Hibernate' features are only available with SCS Standard and higher licenses.
PAUSE immediately and HIBERNATE
Immediately pauses the selected cues and 'hibernates' them. See below for information on 'Hibernating Cues'.
FADE OUT and then HIBERNATE
Causes the selected cues to be faded-out provided those cues have a fade-out time specified, or a Time Override for Fades has been entered. At the end of the fade-out, the cue will will be paused and marked as 'hibernating'.
RESUME hibernating cue (with fade in if applicable)
Resumes hibernating cues, fading in the cues if they have a fade-in time, or a Time Override for Fades has been entered.
RESUME hibernating cue at start of next track
Resumes hibernating playlist cues at the start of the next track. This is useful if you have a single playlist cue for pre-show and intermission, and you fade out and hibernate the cue at the end of pre-show and want to resume at the beginning of a track for intermission.
Time Override for Fades: This field enables you set or override the fade-in or fade-out time for cues affected by this SFR cue. Leave the field blank if no override is required, or if it is not applicable. For example, you can set up an Audio File cue without a fade-out time but implement a fade-out when this SFR cue is actioned by (a) selecting action 'FADE OUT and then STOP', and (b) Setting the required fade-out time in this Time Override for Fades field.
Tip: Time Override for Fades is particularly useful for playlist cues that you want to hibernate or resume from hibernation. The playlist cue itself has fields for fade-in time and fade-out time, and these will be used when you start and terminate the playlist. They will also be used when you hibernate the playlist or resume the playlist from hibernation. However, if you do not want to fade-in your playlist cue at the start but do want to fade-in the cue when it is resuming from hibernation, then you can leave the playlist 'fade-in' time blank (implying no fade-in) but set the required fade-in time in the SFR cue that resumes the playlist from hibernation. Same applies to fade-out.
'Complete' any associated auto-start cues: This feature is only available for 'STOP Immediately' and 'FADEOUT and then STOP' actions. This is useful if you set up an SFR hotkey cue to fade out and/or stop all playing cues but do not want auto-start cues to start that may otherwise be started as a result of cues being stopped.
'Go' Next Manual Cue and Time Delay before Issuing 'Go': If you have an SFR cue to stop or fade out playing cues, etc, this enables you to also activate the next manual cue (as in hitting the 'Go' button'). A time delay before 'Go Next' may be supplied, eg enter 2.5 for a 2.5 second delay. Leave the Time Delay field blank to immediately action the 'Go' button.
Hibernating Cues
A number of users have requested the ability to use the same playlist cue several times, such as for pre-show music and then to carry on where it left off for intermission music. To facilitate this it is now possible to put a playlist into hibernation instead of just completing it. When a playlist is hibernated it is faded out (if the playlist has a fade-out time specified) and then paused. The status of the cue is set to 'hibernating', and while it is hibernating it will not be displayed in the cue panels in the lower part of the main window.
To hibernate a playlist you need to use the SFR action "Fade Out and Hibernate", nominating the Playlist cue to be hibernated.
To 'wake up' a hibernated cue there are two actions available in SFR cues: "Resume hibernated cue" and "Resume hibernated cue at start of next track". When a hibernated cue is resumed, it will again be displayed in the cue panels in the lower part of the main window. The first of these SFR actions (Resume hibernated cue) will continue the playlist from where it was paused, fading in the audio if it was faded out for hibernation. The second of these SFR actions (Resume hibernated cue at start of next track) will skip the remainder of the track that was playing at the time of hibernation, and start playing the next track in the play order.
Tip: Although hibernation is designed for playlists, it is also possible to hibernate and resume an audio file cue or a video cue. With video cues, the paused video image will remain displayed during hibernation.
