MIDI Machine Control Messages
This section of the Help provides details on the SCS support for MIDI Machine Control (MMC) messages. MMC message bytes are principally defined using their hexadecimal values, such as 7FH (7F hexadecimal = 127 decimal).
Device Id: For MMC messages you need to select the Device Id that identifies SCS. SCS accepts MMC messages that have a Device Id that matches the Device Id.
SysEx message to run a cue
The format of a Machine Control message is as follows, where fixed value bytes are shown in hexadecimal:
F0 7F <Device Id> 06 <Command> F7
For SCS the required message format is as shown below:
Byte type
Value
(Hex)
Description
Start byte
F0
Start of SysEx message.
Start of message
7F
Device Id
The 'Device ID' that represents SCS.
SysEx message
06
Denotes a MIDI Machine Control message.
Command
Commands currently recognised by SCS are:
   01 - Stop
   02 - Play
   03 - Deferred Play
   04 - Fast Forward
   05 - Rewind
   09 - Pause
See MMC Commands below for details.
Stop byte
F7
End of SysEx message.
MMC Commands
The MMC commands currently recognised by SCS are as follows:
Stop
All currently running cues are stopped (implemented as per 'Stop All').
Play
Activates the 'Go' button if this button is enabled, otherwise the command is ignored.
Deferred Play
As 'Play'.
Fast Forward
Go to the next manual-start cue (implemented as per 'Go To Next' in the main window's Navigate menu).
Rewind
Go to the previous manual-start cue (implemented as per 'Go Back' in the main window's Navigate menu).
Pause
Pause all running cues, or resume after a previously-issued 'Pause All'. (Implemented as per the 'Pause All / Resume All' button in the main window.)
Back to MIDI Control
