MIDI Show Control Messages
This section of the Help provides details on the SCS support for MIDI Show Control (MSC) messages. MSC message bytes are principally defined using their hexadecimal values, such as 7FH (7F hexadecimal = 127 decimal).
Device Id: For MSC messages you need to select the Device Id that identifies SCS in the MSC network. In an MSC environment each device is uniquely identified by assigning a Device Id, although you can have more than one device sharing the same Device Id. Select an Device Id in the range 00H to 7EH. For an individual device you should select a Device Id in the range 00H to 6FH, as Device Id's in the range 70H to 7EH are allocated to Group Id's. SCS accepts MSC messages that have a Device Id that matches the MSC Device Id and also MSC messages that have a Device Id of 7FH ("All Call").
MSC Command Format: This should normally be left at the default setting of 10H, which is the Sound (General Category) format. Sometimes, however, you may want to link SCS to a controller that sends MSC messages using a different format. For example, the ETC Express lighting desk sends MSC commands using format 01H - Lighting (General Category) as it is intended for controlling other lighting desks. If, in fact, you are using it to control SCS cues then you need to set this Command Format to 01H. If you can select a command format on the controller then you should select 10H for sound cues.
'Go' Button Macro #: This identifies the Fire command's macro number that activates the SCS 'Go' button. The default setting is macro 0, but the device you are using to send MSC commands may not be able to send 0 - some devices only send macro numbers 1 to 127. If you are using the MSC Fire command for activating SCS cues, select the required macro number to be used for the 'Go' button. Note that the number you choose should preferably not be a number you use as a MIDI cue number as this could cause confusion to operators.
SysEx message to run a cue
The format of a Show Control message is as follows, where fixed value bytes are shown in hexadecimal:
F0 7F <Device Id> 02 <Command Format> <Command> <Data> F7
For SCS the required message format is as shown below:
Byte type |
Value |
Description |
MSC Commands
The MSC commands currently recognised by SCS are as follows:
GO |
If no cue number is supplied, the Go button is activated, starting the next manually started cue in the cue list. Note that in SCS this could be any type of cue, ie a sound file cue, a stop cue, a level change cue, or a cue containing any combination of cue types. If a cue number is supplied, the SCS cue whose MIDI Cue Number matches the Q_number is activated. If no such cue is found the command is ignored. |
STOP |
If no cue number is supplied, all currently running cues are stopped. If a cue number is supplied, the SCS cue whose MIDI Cue Number matches the Q_number is stopped. If no such cue is found the command is ignored. The MSC STOP command stops cues immediately, ignoring fade out settings. If you require a cue to be faded out then as well as specifying a fade-out time for the cue you need to create a Stop Cue for that cue, and use the MSC GO command to activate the Stop Cue instead of using the MSC STOP command. |
FIRE |
SCS does not have a macro facility but MSC Fire Macro messages can be used to activate SCS cues as follows: If the macro number is matches the 'Go Macro', the Go button is activated, starting the next manually started cue in the cue list. If the macro number does not match the 'Go Macro', the SCS cue whose MIDI Cue Number matches the macro number is activated. If no such cue is found the command is ignored. |
