MIDI Program Change Messages
SCS supports the control of cues by MIDI Program Change messages. If your sending device or software uses program numbers in the range 0-127 then use Control Method Prg Chg (0-127). If your sending device or software uses program numbers in the range 1-128 then use Control Method Prg Chg (1-128).
Program Control messages are mapped to SCS MIDI cue numbers as follows:
SCS |
Program Change (0-127) |
'Go' Button |
Program change 0 |
Play Cue 1 - 127 |
Program change 1 - 127 |
SCS |
Program Change (1-128) |
Play Cue 1 - 127 |
'Go' Button |
Program change 128 |
MIDI Channel: Select the MIDI Channel (1-16) that SCS is to monitor for these cue control messages.
