Production Properties - Video Capture Devices
Video Capture Devices are devices that provide live video feeds, which normally would be video cameras. The term 'video capture' is used widely in the industry for devices that can 'capture a video signal' for transmission to a computer or other device.
Video Capture in SCS is only supported when TVideoGrabber (TVG) is selected as the Video Playback library in Video Driver Options.
Here's an example of the Production Properties for Video Capture Devices:
Devices Required in Cues
Here you need to identify each video capture device you want to use in Video Capture cues. You give each device a Name that will be used in your Video Capture cues.
Device Number (V1, V2, etc): If this number is displayed with a colored background (eg see V1 in the above screenshot) this indicates this device is the 'current' device for the Sidebar Controls to the left, and for the 'Default Settings' panel displayed below the device list. To make a different device the 'current' device, click on any field in the line for the required device, or on the Device Number itself.
Name Used in Cues: Enter the name you want to use for the audio output in your Video/Image cues.
Computer-Specific / Device Map-Specific Fields
Device Map: This is a display-only field showing the Device Map currently selected for this production in the Audio Output Devices tab.
Physical Device: The DirectSound device assigned to this Name Used in Cues. Note that the Video Playback Library used by SCS only handles DirectSound devices. It is not possible to select an ASIO device or a SoundMan-Server output channel. If you select 'Default Audio Device' then this will map the Name used in Cues device to the current Windows default sound device. This handles situations where an external audio interface may or may not be connected, and where Windows may change the default sound device accordingly. 'Default Audio Device' uses whatever audio device is currently assigned by Windows as the default.
If you are running SCS in an ASIO-only environment then 'Default Audio Device' may still be selected but audio output from videos will be muted.
Gain and dB: This is like a Master Gain Control for this physical output in this Device Map. Normally you should leave the gain at the default setting of maximum gain (0.0dB). See the corresponding property under Audio Output Devices for more info.
Default Settings
Auto-Include this device when adding new cues: If this checkbox is selected then whenever you add a new Video/Image Cue then this device will automatically be included. One and only one Video Audio Device may have auto-include selected as Video/Image cues only support a single audio device. Note that this property only affects future cues added - changing the setting has no effect on existing cues.
Default level and pan when adding this device to a cue: This gives the trim, level and pan to be used when adding this device to a cue. You can, of course, subsequently change the trim, level and pan in the cue itself.
< Previous Topic (Audio Output Devices)  |  Next Topic (Live Inputs) >
