Note Cues are only available with SCS Standard and higher license levels.
A Note Cue is a cue without any sub-cues. Use the cue Description field for your note. When a Note is displayed in the cue display panels the description is highlighted. The Note is cleared from the list by 'playing' the cue.
See also Memo Cues.
NB A 'Note' cue is not the same as a 'Hotkey (Note)' or 'External (Note)' cue.
