MIDI ETC Messages
SCS supports the control of cues using MIDI messages sent from an ETC Express lighting console using the AB Fader Pair or CD Fader Pair. Other devices or software that can send Program Change and/or Controller Change messages that match the information below can also use one of these ETC Control Methods. The formats are mapped to MIDI cue numbers as follows:
SCS
ETC AB
'Go' Button
Program change 0
Play Cue 1 - 127
Program change 1 - 127
Play Cue 128 - 255
Controller change 70, value 0 - 127
Play Cue 256 - 383
Controller change 71, value 0 - 127
Play Cue 384 - 511
Controller change 72, value 0 - 127
Play Cue 512 - 639
Controller change 73, value 0 - 127
Play Cue 640 - 767
Controller change 74, value 0 - 127
Play Cue 768 - 895
Controller change 75, value 0 - 127
Play Cue 896 - 999
Controller change 76, value 0 - 103
SCS
ETC CD
'Go' button
Controller change 77, value 0
Play Cue 1 - 127
Controller change 77, value 1 - 127
Play Cue 128 - 255
Controller change 78, value 0 - 127
Play Cue 256 - 383
Controller change 79, value 0 - 127
Play Cue 384 - 511
Controller change 80, value 0 - 127
Play Cue 512 - 639
Controller change 81, value 0 - 127
Play Cue 640 - 767
Controller change 82, value 0 - 127
Play Cue 768 - 895
Controller change 83, value 0 - 127
Play Cue 896 - 999
Controller change 84, value 0 - 103
MIDI Channel: Select the MIDI Channel (1-16) that SCS is to monitor for these cue control messages.
Back to Cue Control Devices - MIDI
