MIDI Note On Messages
SCS supports the control of cues by MIDI Note On messages. These are mapped to SCS MIDI cue numbers as follows:
SCS
Note On
'Go' Button
Note On 0
Play Cue 1 - 127
Note On 1 - 127
MIDI Channel: Select the MIDI Channel (1-16) that SCS is to monitor for these cue control messages.
NB undefined bytes in the MIDI messages, such as the 'velocity' for Note On messages, may contain any value.
However, Note On messages with a velocity of 0 are converted internally to Note Off messages.
The above MIDI Message Assignments are set by default when 'MIDI Note ON' is selected as the Control Method. Other Cue Control Commands may be set as required, eg 'Stop Everything' may be assigned a Control Change message.
Back to Cue Control Devices - MIDI
