Palladium Messages
SCS supports the control of cues by MIDI messages sent by Palladium, which is a sound control system developed and marketed by CH Sound Design (www.chsounddesign.com). SCS can be used as a playback source for Palladium, and you can download Palladium playback files for SCS from the Palladium web site.
These MIDI messages are mapped to SCS MIDI cue numbers as follows:
SCS
Palladium
'Go' Button
Note On 0
Play Cue 1 - 127
Note On 1 - 127
Pause/Resume Cue 1 - 127
Note Off 1 - 127
Go To Cue 1 - 127
Program Change 1 - 127
Load Cue 1 - 127
Key Pressure 1 - 127
Unload Cue 1 - 127
Channel Pressure 1 - 127
Stop Everything
Control Change 123, value 0
MIDI Channel: Select the MIDI Channel (1-16) that SCS is to monitor for these cue control messages.
NB undefined bytes in the MIDI messages, such as the 'velocity' for Note On and Note Off messages, may contain any value.
However, Note On messages with a velocity of 0 are converted internally to Note Off messages.
Back to Cue Control Devices - MIDI
