This help file is for SCS Version 11.8.2.1.
Prerequisites
How SCS Works - Please read!
Main Window Toolbar
Video/Image Cues on the Main Window
Find Cue
Clock Timers
New Production
Use Template
Open Favorite
Open Existing
Starting and Using the Editor
Editor Toolbar
Editor Sidebar
Production Properties
Devices
Audio Output Devices
Video Audio Devices
Video Capture Devices
Live Inputs
Input Groups
Fixture Types
Control Send Devices - MIDI
Control Send Devices - RS232
Control Send Devices - HTTP
Cue Control Devices - MIDI
Cue Control Devices - RS232
Cue Control Devices - Network
Cue Control Devices - DMX
VST Plugins
Run Time Settings
Cue Properties
Callable Cues
Hotkey Banks
Cue Types
Lighting Cues
MTC/LTC Cues
Memo Cues
Go To Cues
Set Position Cues
Run External Program Cues
Copy, Move, Delete or Sort a Range of Cues
Drag and Drop
Import Cues from a CSV File
General Options
Display Options
Cue List Columns
Video Driver Settings
Remote App Interface
Shortcuts
Editing Options
Session Options
Starting SCS
Using SCS Sliders
Sound File Recommendations
Device Maps
Auto-Starting a Cue File
MIDI Time Code (MTC)
DMX Display Window
Setting up a Backup Computer
Playing Cues for a Show
Problem Starting SCS
Video Problems
ASIO Problems
Outputs 3/4 and 5/6 Swapped
Diagnostic File
Credits
Registering SCS
Recent Changes
