Control Send - MIDI Show Control (MSC)
The table below explains the fields available for MIDI Show Control (MSC) Control Send cues. Most numbers in drop-down lists are shown with the hexadecimal value first as this is most commonly used.
Device Id: Select the required destination Device Id from the drop-down list (range 00H to 7FH). Command Format: Select the Command Format from the drop-down list (range 00H to 7FH). Standard descriptions of a number of Command Formats are displayed in the list. Command: Select the Command from the drop-down list (range 00H to 1EH). Standard descriptions of Commands are displayed in the list. The Data fields displayed are determined from the selected Command. |
Commands 01H (Go), 02H (Stop), 03H (Resume), 05H (Load), 0BH (Go Off) and 10H (Go/Jam Clock) Q Number: Optional; required if Q List is sent. Enter the required Cue Number, which may contain digits and decimal points, eg 235.6 Note: If the previous Q Number entered was an integer (no decimal point) then on displaying the fields for a new command, SCS will populate the Q Number field with a value one greater than the previous Q Number. Q List: Optional; required if Q Path is sent. Enter the required Cue List, formatted as for Q Number. Q Path: Optional. Enter the required Cue Path, formatted as for Q Number. |
Command 06H (Set) Control Number: Enter the required Control Number. Legal values are in the range 0 to 16383 but your device may have other limits. Control Value: Enter the required Control Value. Legal values are in the range 0 to 16383 but your device may have other limits. |
Command 07H (Fire) Macro Number: Select the required Macro Number from the drop down list, in the range 0 (00H) to 127 (7FH) |
Commands 08H (All Off), 09H (Restore) and 0AH (Reset) These commands do not require data fields. |
Other Commands Data fields for other commands are not yet implemented in SCS. If you have a particular requirement for a Command Data format not yet implemented, contact SCS Support. |
