Some features only available with SCS-Standard and/or higher license levels.
Various SCS commands are available using the keyboard. Most of these are configurable - see Options and Settings - Shortcuts for details. The table below explains just some the keyboard shortcuts, assuming the default keyboard assignments.
Tip: Key presses are sent by Windows to the program window that currently has focus (if any). So if you've accessed another program or system pop-up and then closed that program or pop-up, focus will not necessarily be reset to the SCS main window. If you don't realize that when you next press a key for SCS (eg the space bar to start a cue, or a hot key), then SCS does nothing because it didn't receive the keypress event from Windows.
To warn you about this, SCS displays a warning in the status line of the main window if the main window loses focus. SCS checks every 5 seconds (sometimes more often) to see if the main window has focus, and if not then a warning message is displayed in the status line. Just left-click on the warning message to re-establish focus on that window.
This is primarily to assist you during performances. Checking for focus every 5 seconds is canceled if you use the Editor or the Options screen. Checking for focus is reinstated the next time you start SCS.
Default Key
Function
Explanation
General commands
Space
'Go' Button
Start the next cue
Esc
Stop Everything
'Panic button' - stops all cues immediately.
Ctrl + U
Pause/Resume All
Pauses (or Resumes) all playing cues.
Master Fader
Num Pad Add
Master Fader Up
Increase the overall level.
Num Pad Subtract
Master Fader Down
Decrease the overall level.
Num Pad Multiple
Master Fader Reset
Reset the Master Fader to the original level (shown by the white pointer).
Shift + Num Pad Subtract
Master Fader Mute
Mute/Unmute all outputs.
Change Levels Of Playing Cues
Shift + F11
Decrease levels of playing cues.
Shift + F12
Increase levels of playing cues.
Ctrl + F11
Decrease level of last playing cue (no action if the last playing cue has completed)
Ctrl + F12
Increase level of last playing cue (no action if the last playing cue has completed)
Save Settings
Shift + F10
Save Settings (all Cues)
Equivalent of the 'Save Settings' menu item 'Save Level/Pan for all above Cues'.
Cue List Navigation
Up Arrow
Cue List Up One Row
Go up one row in the cue list. Note that this is not necessarily the same as the 'Go Back' navigation item, as 'Go Back' will go back to the previous manual-start cue.
Down Arrow
Cue List Down One Row
Go down one row in the cue list. Note that this is not necessarily the same as the 'Go To Next' navigation item, as 'Go To Next' will go to the next manual-start cue.
Page Up
Cue List Up One Page
Go up one page in the cue list.
Page Down
Cue List Down One Page
Go down one page in the cue list.
Home
Cue List Top
Go to the top of the cue list, ie to the first cue.
End
Cue List End
Go to the 'End' line of the cue list.
Ctrl + Left Arrow
Previous Image
These two keys are designed to allow you to easily step backwards and forwards thru a slideshow, especially where you have image cues set to 'continuous play', where the whole display of the slideshow is manually controlled.
If an image cue is being displayed when you use 'next image' or 'previous image', then SCS will reposition the cue list at the next or previous cue and play that cue. If an image cue is not being displayed when you use 'next image' or 'previous image', then SCS will reposition the cue list at the next or previous cue, but will not start that cue.
Although these keys are designed for Image Cues, they work on all cue types.
Please note that currently these commands work at the cue-level, not the sub-cue level. So if you have multiple image sub-cues in a cue then using one of these functions will not go to the next or previous sub-cue but to the next or previous cue.
Ctrl + Right Arrow
Next Image
Other commands
Ctrl + Shift + A
Favorite File #1
Open file #1 in your Favorite Files list. Subsequent keys open subsequent Favorite Files, eg Ctrl + Shift + B will open Favorite File #2.
Ctrl + Shift + F1
Hotkey Bank 1
Select Hotkey Bank 1. Subsequent keys select subsequent Hotkey Banks, eg Ctrl + Shift + F2 selects Hotkey Bank 2. Note that there is no shortcut key to de-select the current Hotkey Bank, ie no shortcut key to select Hotkey Bank 0. Also, note that Ctrl + Shift + F10 will not work as this is used by Windows.
Editor Transport Controls
F4
Rewind
F5
Play/Pause
F6
Stop
F7
Add an SCS Cue Marker
Not really a 'transport control', but pressing F7 while playing an Audio File Cue in the Editor will add an SCS Cue Marker at the current position. See SCS Cue Markers for more info.
Back to The Main Window
