Many SCS users prepare files and cues on their PC at home or in a studio and then transfer the files to a different PC at the theatre. The physical path name of files on your home PC may be different to those on the theatre PC, but SCS enables you to easily transfer your files as follows:
The simplest way to transfer your files is to follow these steps: 1.Collect your files into a Production Folder on your home or studio computer. 2.Remove the external drive (if applicable). 3.On your theatre PC copy the Production Folder from your external or network drive to the hard disk. 4.If you have not already done so, install SCS on your theatre PC. 5.Start SCS on your theatre PC and open the cue file (the .scs11 file) from the Production Folder you have just copied onto this PC. |
See also: Device Maps
