Run Screen Ribbon Bar
Some features only available with SCS-Standard and/or higher license levels.
Cue Control |
Go! |
The Go button is used to start the next cue. Alternatively you can right-click the mouse to start the next cue, or use a keyboard key such as the space bar to start the cue. To disable or change keyboard activation see Key Mapping. The "next cue" is the "next manual-start cue" because auto-start cues do not need to started by the Go button. The label of the cue to be started is displayed in the button caption. |
Pause All |
This can be regarded as an alternative to Stop All (described below). The difference is that whereas Stop All stops and resets running cues, Pause All will just pause all running cues and countdowns, and Resume All may then be used to resume those cues and countdowns. A single button is used, initially labelled Pause All. If the button is clicked the label is changed to Resume All. Note that in either mode the button can be keyboard-activated by Alt/u. |
Stop All |
This is the panic button, although you will usually use the keyboard equivalent, which is the Esc (Escape) key. Stop All causes all currently running cues to be stopped immediately (not faded out), and if any cue is currently counting down to a start that count down is stopped. The cue list is then repositioned at the start of the first cue that was stopped by Stop All. The usual situation where you would use this is where you accidentally start a cue before time. If you then hit Esc the cue will stop immediately and the cue list will be reset ready for you to play the cue at the right time! |
Navigate |
Navigate can be used to navigate around the cue list. The button has a drop-down menu which contains Go To Top (go to the top of the cue list), Go Back (go back to the previous manual-start cue), Go To Next (go to the next manual-start cue), and Go To End (go to the end of the cue list). Note that instead of using the Navigate button you can just click in the cue list on the cue you want to go to. |
Standby |
The Standby button is only displayed if at least one cue in your current cue file has a 'Set Standby' property. When that cue has completed it is reset to 'Ready' and the Standby button is enabled and the cue number is shown in the button caption. That cue may then be replayed by clicking on the Standby button, regardless of how much further thru the cue list you have progressed. See Standby Cues for details. |
Select Time Profile |
TheSelect Time Profile button is only displayed if at least one cue in your current cue file is a time-based cue, ie it is set up to be started at a nominated time of day. For time-based cues you may have different Time Profiles, such as 'Evening' and 'Matinee'. One of these Time Profiles will be set as the default Time Profile, ie the one initially selected when the cue file is opened. However, using the Select Time Profile button you can switch to a different Time Profile. See Time-Based Cues for details. |
File |
New |
The New button is for creating a new cue file. If there are unsaved changes in your current cue file then you will be asked if you want to save those changes. After selecting New you should then click the Editor button so you can build your new cue file. |
Open |
The Open button is for opening an existing cue file. Note that the button has a small down-arrow displayed, so shows a drop-down menu which includes recent files. If there are unsaved changes in your current cue file then you will be asked if you want to save those changes. |
Save |
The Save button shows a drop-down menu enabling you to Save current changes or Save As a new cue file. |
The Print button opens the SCS Print dialog to enable you to print a hard copy of your cue list. See Printing the Cue List for details. |
Options |
Display Options |
Display Options allow you to select what you want displayed, and how you want it displayed, within the scope of the options provided. Your Display Options are saved in the Windows Registry (current user) and are therefore remembered between sessions They are global - ie they are not specific to any cue file. This also means that Display Options are not saved in the cue file and will therefore not be transferred to another computer if you copy your cue file to another computer. The Display Options button has the following items on a drop-down menu:
General Options |
There are two items in the General Options drop-down menu: Permanent Options and Session Options. Permanent Options will open an options window - see Permanent Options for details. These options are saved in the Windows Registry, just like the Display Options. Session Options are not saved anywhere - they only apply to the current session. Individual session options are only enabled if applicable, and include:
Tip: There is a key difference between Display Options and General Options. Display Options affects how the SCS Run Screen is displayed; General Options affects how SCS behaves, eg what MIDI port to use for MIDI control of cues. The Lock Editing button (described later) can be used to lock not just the Editor but also General Options, so if you hand over the running of cues to another operator then you can lock them out of General Options as well as the Editor. |
Editing |
Editor |
Click the Editor button to open the SCS Editor Window. This is for setting up or changing cue details, production details, importing or exporting cues, etc. You can switch back to the Run Screen any time you wish - you do not have to close the Editor to do this. Note that the Editor can be locked, which is useful when you have finalized your cue file and want to prevent operators making changes. |
Device Mapper |
The Device Mapper is where you 'map' physical devices to logical devices, ie it is where you select the physical outputs to be used for the devices you have defined in your Production Properties. For example, you may want front and rear speakers for your production, with the ability to send different sounds to front and rear. To achieve this you could set up two devices in your Production Properties, named 'Front' and 'Rear', or whatever you want to call them. In the Device Mapper you will select the actual output(s) to be mapped to the 'Front' device, eg UA101 Outputs 1-2, and the output(s) to be mapped to the 'Rear' device, eg UA101 Output 3. Device Maps are kept on each computer, so if your cue design computer has different audio hardware to your production computer, that is not a problem. On your design computer you will map 'Front' and 'Rear' to the outputs you have available on the design computer, and on your production computer you will map 'Front' and 'Rear' to outputs available on the production computer. |
Save Settings |
Save Settings is enabled if you manually change the level or pan of a cue, or if you adjust the Master Fader. A drop-down menu is displayed. The first two entries refer to the Master Fader, and are: If you have manually change the level or pan of any cues, you will see a menu item for each one, eg: Clicking one of the above menu items immediately applies that change in the cue file. This list will handle saves to the level and pan settings for up to 20 cues - after that the oldest one gets rolled off the list. If there are two or more cues in the Save Settings list then you can save all the Level/Pan settings by clicking on: Please note that if a Level Change cue has affected an Audio or Video cue, then 'Save Settings' will not be available for manual changes to that Audio or Video cue. |
Lock Editing |
This button opens a dialog window that enables you to lock the Editor, Device Mapper, Save Settings and General Options. The facility is password-controlled, using a 'Sound Designer Password'. If you have not yet specified a 'Sound Designer Password', or if you have forgotten the password, then you can click on a link to open a window to enter a new password. That window requires you to enter your SCS Authorization String to confirm the authenticity of the request. When the lock is in place, the caption on the button is changed to Unlock Editing. This action is also, of course, password-controlled. |
Help |
Help |
This button displays the following menu items:
