Permanent Options
The Permanent Options window (accessed via the General Options button in the ribbon bar) enables you to specify settings that are to be used whenever you run SCS on this computer. These are settings that are not specific to any one production, but which are applicable or potentially applicable to all cue files used on this computer. The settings are save in the Windows Registry (current user) so are not transferred to another computer if you copy a cue file.
In the Options window there are several groups of options, which can be selected by clicking the appropriate tab:
· Audio Driver - BASS Audio Library
· Audio Driver - SoundMan-Server
Saving your Options
To save any changes you have made to Options, click the OK button. To cancel any changes, click the Cancel button.
