This help file is for SCS Version 11.10.5.
IMPORTANT: ALWAYS, repeat ALWAYS complete at least one dry run (a 'dry tech') of the entire show at least a week before the first performance or first dress rehearsal of any show. This is to give you the opportunity to identify and fix any issues ahead of time.
NOTE: If the Help pages appear to be wrongly formatted, or if the SCS version number in the title bar is incorrect, then either clear your browser's cache or select 'Reload' from a right-click on the help page title.
•Overview
•Prerequisites
•How SCS Works - Please read!
•Running the Demo
•Feature Comparison
•Main Window Toolbar
•Meter Display and Master Faders
•Changing the Levels of All Playing Cues
•Cue Panels
•Linking Audio Device Levels
•Cue and Sub-Cue Descriptions
•Keyboard Shortcuts
•Find Cue
•Clock Timers
•New Production
•Use Template
•Open Favorite
•Open Existing
•External 'Control Surface' Setup
•Starting and Using the Editor
•Editor Toolbar
•Editor Sidebar and Cue List
•Undoing, Redoing and Saving Your Changes
•Production Properties
•General
•Devices
•Audio Output Devices
•Video Audio Devices
•Video Capture Devices
•Fixture Types
•Lighting - DMX Devices and Fixtures
•Control Send Devices - MIDI
•Control Send Devices - RS232
•Control Send Devices - Network
•Control Send Devices - HTTP
•Cue Control Devices - MIDI
•Cue Control Devices - RS232
•Cue Control Devices - Network
•Cue Control Devices - DMX
•Live Inputs
•Input Groups
•VST Plugins
•Time Profiles
•Run Time Settings
•Import Devices from another SCS Cue File
•Cue Properties
•Time-Based Cues
•Callable Cues
•Standby Cues
•Re-Number Cues
•Cue-Start Confirmation
•Hotkey Banks
•Cue Types
•Audio File Cues
•Stop / Fade-Out / Release (SFR) Cues
•Level Change Cues
•Playlist Cues
•Video/Image Cues
•Lighting Cues
•Control Send Cues
•MTC/LTC Cues
•Note Cues
•Memo Cues
•Go To Cues
•Set Position Cues
•'Call Cue' Cues
•Run External Program Cues
•Enable/Disable Cues
•Live Input Cues
•Collect Production Files
•Bulk Edit Cues
•Copy Properties from another Cue or Sub-Cue
•Copy, Move, Delete or Sort a Range of Cues
•Drag and Drop
•Import Cues from another SCS Cue File
•Import Cues from a CSV File
•Export Cues to a new SCS Cue File
•General Options
•Display Options
•Cue List Columns
•Audio Driver Settings - DirectSound/WASAPI
•Audio Driver Settings - ASIO (BASS)
•Audio Driver Settings - ASIO (SM-S)
•Video Driver Settings
•Remote App Interface
•Functional Mode (Primary/Backup)
•Shortcuts
•Editing Options
•Session Options
•Encoded Files Folder
•Starting SCS
•Time Fields
•Using SCS Sliders
•Sound File Recommendations
•Gapless Playback
•Printing the Cue List
•Device Maps
•Portability (transferring your files to another computer)
•Special Folders
•Auto-Starting a Cue File
•Production Timer
•MIDI Time Code (MTC)
•DMX Display Window
•Lighting Control by External Fader
•Setting up a Backup Computer
•Move to Time (M2T)
•Group Cues
•Setting Up For a Production
•Setting Up Your Video Projector For Videos and Still Images
•Playing Cues for a Show
•Problem Starting SCS
•Video Problems
•Fixing Stuttering or Skipping Audio
•ASIO Problems
•Outputs 3/4 and 5/6 Swapped
•Linked Audio Files Out Of Sync
•Credits
•Terms and Conditions
•Registering SCS
•Recent Changes
