This help file is for SCS Version 11.10.7.
NOTE: If the Help pages appear to be wrongly formatted, or if the SCS version number in the title bar is incorrect, then either clear your browser's cache or select 'Reload' from a right-click on the help page title.
Prerequisites
How SCS Works - Please read!
Main Window Toolbar
Linking Audio Device Levels
Find Cue
Clock Timers
New Production
Use Template
Open Favorite
Open Existing
Starting and Using the Editor
Editor Toolbar
Editor Sidebar and Cue List
Production Properties
Devices
Audio Output Devices
Video Audio Devices
Video Capture Devices
Fixture Types
Control Send Devices - MIDI
Control Send Devices - RS232
Control Send Devices - HTTP
Cue Control Devices - MIDI
Cue Control Devices - RS232
Cue Control Devices - Network
Cue Control Devices - DMX
Live Inputs
Input Groups
VST Plugins
Run Time Settings
Cue Properties
Callable Cues
Hotkey Banks
Cue Types
Lighting Cues
MTC/LTC Cues
Memo Cues
Go To Cues
Set Position Cues
Run External Program Cues
Copy, Move, Delete or Sort a Range of Cues
Drag and Drop
Import Cues from a CSV File
General Options
Display Options
Cue List Columns
Video Driver Settings
Remote App Interface
Shortcuts
Editing Options
Session Options
Starting SCS
Using SCS Sliders
Sound File Recommendations
Device Maps
Auto-Starting a Cue File
MIDI Time Code (MTC)
DMX Display Window
Lighting Control by External Fader
Setting up a Backup Computer
Move to Time (M2T)
Group Cues
Playing Cues for a Show
Problem Starting SCS
Video Problems
ASIO Problems
Outputs 3/4 and 5/6 Swapped
Credits
Registering SCS
Recent Changes
